Low Voltage Barrier for Echo Zone Controllers
I need to run the data cable in conduit. Is there a low voltage barrier available to separate the high and low voltage in a junction box?
Explanation of Issue
Occasionally it is necessary to run data cables in conduit instead of free air.  To accommodate this, ETC has created a junction box with a low voltage barrier and special cover plate to mount your zone controller in a manner that will allow for AC and DC wired to be run to it in conduit.
If this option is needed, please order ETC Part Number: 7187A1000
