Sensor IQ 48 Channel Main Breaker and Main Fuse Options
If a 48-channel Sensor IQ panel is fed with a 400A feed, a 65kA breaker must be used. However, if you are feeding a Sensor IQ 48-channel panel with a 100A or 200A feed, the 22kA breakers are OK to use.
Breakers are rated per pole/phase. So, a Main Breaker: 277/480V (240/415V), 100A will support 100Aper phase NOTE: Per the NEC, a 100A breaker can only be loaded to 80% or in your case(100A main) 80A per phase.
Below is a list of the Main Breaker kits and Main Fuse Kits offered by ETC.
Main Breaker Kits:
120v Panels:
Main Breaker options – 22kA
- IQ-MB100A22K
- Main Breaker: 120/208V, 100A, 22kA SCCR
- IQ-MB200A22K
- Main Breaker: 120/208V, 200A, 22kA SCCR
- IQ-MB250A22K
- Main Breaker: 120/208V, 250A, 22kA SCCR
- IQ1-MB100A22K
- Main Breaker: 120/240V, 100A, 22kA SCCR
- IQ1-MB200A22K
- Main Breaker: 120/240V, 200A, 22kA SCCR
Main Breaker options – 65kA
- IQ-MB100A65K
- Main Breaker: 120/208V, 100A, 65kA SCCR
- IQ-MB200A65K
- Main Breaker: 120/208V, 200A, 65kA SCCR
- IQ-MB225A65K
- Main Breaker: 120/208V, 225A, 65kA SCCR
- IQ-MB400A65K
- Main Breaker: 120/208V, 400A, 65kA SCCR
- IQ1-MB400A65K
- Main Breaker: 120/240V, 400A, 65kA SCCR
240/277v Panels:
- IQ277-MB100
- Main Breaker: 277/480V (240/415V), 100A
- IQ277-MB200
- Main Breaker: 277/480V (240/415V), 200A
- IQ277-MB400
- Main Breaker: 277/480V (240/415V), 400A
BE AWARE: 240v and 277v Main Breaker Kits serve as a disconnect only. They do not increase series SCCR rating of the Sensor IQ panel.
Main Fuse Kits:
120v Panels:
Main Fuse options – 65kA
- IQ-MF1003P
- Main Fuse: 120/208V, 100A, 65kA SCCR
- IQ-MF2003P
- Main Fuse: 120/208V, 200A, 65kA SCCR
- IQ-MF1002P
- Main Fuse: 120/240V, 100A, 65kA SCCR
- IQ-MF2002P
- Main Fuse: 120/240V, 200A, 65kA SCCR
240/277v Panels:
- IQ277-MF200
- Main Fuse Kit: 277/480V (240/415V), 200A, 65kA SCCR
