OSC Commands for ColorSource AV Console
The following information was pulled from the v2.0 User Manual.
This information can also be found on the console by pressing and holding "?" in the upper left corner.
Note: Arguments are shown following an equal sign (=). For OSC, these are not sent as a part of the OSC string itself, but instead attached as arguments. Configuration will vary depending on the software you are using.
Buttons
Command
Variables /Arguments
Description
/cs/key/recordsnapshot
Records a snapshot of the active state in a memory
/cs/key/recordnextcue
Records the active state into the next cue
/cs/key/clearall
Clears all the selections, active channels, playbacks and cues
/cs/key/clearplaybacks
Clears the active playbacks
/cs/key/clearcues
Clears the active cue
/cs/key/clearchannels
Clears the active channels
/cs/key/clearselection
Clears the user's selected channels
/cs/key/blackout
Toggles the blackout state
/cs/key/audiomute
Toggles audio mute
/cs/key/videooff
Toggles video output
/cs/key/mediapause
Pauses or plays media
/cs/key/ind1
Toggles Ind1
/cs/key/ind2
Toggles Ind2
Cue
Command
Description
/cs/playback/go
Runs the next cue
/cs/playback/goback
Runs the previous cue
/cs/playback/pause
Pauses an active cue change
/cs/playback/gotocue/x
x: cue number
Runs cue number x
***gotocue is not listed in the manual or on the console.  It works in v.1.1.4, but does not work in v.2.0, it is working in v.2.5.0
Channels
Command
Description
/cs/chan/select/{x}
x: channel number, no arguments
Exclusively select channel x
/cs/chan/select=x
x: channel number, 1 integer argument
/cs/chan/add/{x}
Add channel x to selection
/cs/chan/add=x
/cs/chan/subtract/{x}
Remove channel x from selection
/cs/chan/subtract=x
/cs/chan/thru/{x}
Select every channel from the last channel selected 'thru' to channel x
/cs/chan/thru=x
Groups
Command
Description
/cs/locationGroup/select/{x}
x: location group number, no arguments
Selects all the channels in the location group x
/cs/locationGroup/select=x
x: location group number,1 integer argument
/cs/tagGroup/select/{x}
x: tag group number, no arguments
Selects all the channels in the tag group x
/cs/tagGroup/select=x
x: tag group number,1 integer argument
Level - Parameters - Color
Command
Description
/cs/chan/at/{x}
x: value [0-100], no arguments
Puts the selected channel at level x
/cs/chan/at=x
x: value [0-100],1 integer argument
/cs/chan/wheel/{x}
x:step amount [0-255], no arguments
Steps the selected channel's level by x
/cs/chan/wheel=x
x:step amount [0-255],1 integer argument
/cs/param/pan/wheel/{x}
x:step amount, no arguments
Steps the selected channel's pan value by x
/cs/param/pan/wheel=x
x:step amount,1 integer argument
/cs/param/panTilt/{x}/{y}
x: pan value [0-100] y: tilt value [0-100]
Steps the selected channel's pan value by x and tilt value by y
/cs/param/panTilt=x,y
x: pan value [0-100] y: tilt value [0-100],
2 integer arguments – pan, tilt
/cs/param/tilt/wheel/{x}
Steps the selected channel's tilt value by x
/cs/param/tilt/wheel=x
/cs/color/hs/{x}/{y}
x: hue value [0-360] y:saturation value [0-100]
Sets the selected channel's color to hue x and saturation y
/cs/color/hs=x,y
x: hue value [0-360] y:saturation value [0-100], 2 integer arguments- hue, saturation
/cs/color/select/{x}
x: color chip number, no argument
Sets the selected channel's color to the color chip x
/cs/color/select=x
x: color chip number, 1 integer argument
Playbacks
Command
Description
/cs/playback/{x}/activate
x: playback number
Activates the playback x
/cs/playback/{x}/fire/press
x: playback number
Performs bump button press for playback x
/cs/playback/{x}/fire/{y}
x: playback number y: toggle [0 or 1]
Controls bump button press for playback x, 1 for button pressed,
0 for button released
/cs/playback/x/fire/y
No arguments
/cs/playback/x/fire=y
1 argument – button pressed (integer)
/cs/playback=x,“fire”,y
3 arguments – playback number (integer), “fire” (string), button pressed (integer)
/cs/playback/{x}/level/{y}
x: playback number y: level [0.0-1.0]
Sets the level of playback x to value y
/cs/playback/x/level/y
No arguments
/cs/playback/x/level=y
1 argument – level (float)
Sets the level of playback x to value y (0.0 to 1.0)
/cs/playback =x,“level”,y
3 arguments – playback number (integer), “level” (string), level (float)
/cs/playbacks/changePage/{x}
Pages the current playback page by x (typically +1 or -1)
/cs/playbacks/changePage=x
x:step amount, 1 integer argument
