Can I Patch the Same Address to a Channel and an Independent
Question
Is it possible to patch a single address to a channel and an independent at the same time?
Answer
Yes, the console will allow you to patch an address to both an Independent and to a channel.  However, the channel will not work to control that address.  The independent is considered a higher priority than anything else from the console and is either at 0% or 100%.  Any address patched to an Independent will not be controllable by the console in any other manner.
