Colorsource Custom Faders Have No Content
The customizable faders do not function and there is only blank space on the screen below them. Playbacks and cues can be recorded, but will not play back.
The customizable faders can be set to a function of "None." Not only does this remove the function from the fader, it removes the graphic bubble which displays the fader's current function. Removing a fader sets that fader's value to 0, so if a fader is removed, the cue, bump, or playback master will be set to 0 and those features cannot be used.
  1. Go to Setup -> Settings -> Console
  2. Tap the green space below an empty fader
  3. Assign the desired function to the fader
  4. Repeat as necessary.
