Fixtures Quickly Flash To Full When Using ColorSource Crossfader
Manually fading cues with the physical crossfader on my ColorSource console causes unexpected behavior. When the crossfader nears 95% (in either direction) random fixtures will flash and then resume their values as normal.
This may be caused by a bug present in software versions 2.5.0 and previous that affects the crossfader. When the fader is moved quickly or very slowly, the bug appears more frequently.
Workaround
While running v2.5.0 code and earlier, use the Play button and enter In/Out times manually in the Cue List editor. A fix for this bug is expected in future ColorSource console software.
