Where is Blackout on the ColorSource console?
Question
I can't find the Blackout function on the ColorSource console. Where can I find it?
Answer
In the top left corner of the LCD you'll find a button with a ? on it. Just to the right of that is a button with several icons that you can tap on, and a ribbon with additional control options will pop out. Tap the "Blackout" button on that ribbon to turn blackout on, and tap it a second time to turn blackout off.
Another solution would be to go into your Setup > Settings window. In there, you can select the "Console" tab.
Within the "Console" tab, you can select one of your five reprogrammable buttons under the display to be the blackout button.
These are the two ways you can access the blackout functionality of the ColorSource Console.
