Manually Update the Cobalt Fader Display Unit (FDU)
Cobalt 10/20
Component
Firmware Version
Keyboard Master
1.1.0.9.0.0
Fader Display Unit
1.0.4.9.0.16 / 1.0.5.0.16*
Independent Master
1.0.1.9.0.5 / 1.0.2.9.0.6*
Playback Master
1.0.3.9.0.8 / 1.0.4.9.0.9*
Full Speed I/O Card (with Phone Remote)
1.4.2.9.0.5
High Speed I/O Card (without Phone Remote)
1.1.0.9.0.4 / 1.1.1.9.0.5*
Cobalt Programming Wing
Component
Firmware Version
Programming Wing
1.1.0.9.0.0
Encoder Board
1.0.1.9.0.9 / 1.0.2.9.0.10*
Playback Master
Full Speed I/O Card
1.4.2.9.0.5
High Speed I/O Card
Cobalt Motorized Fader Wing
Component
Firmware Version
Fader Wing
1.0.4.9.0.21 / 1.0.5.9.0.22*
Cobalt Light Server
Component
Firmware Version
Light Server 10x2 Button
1.1.0.9.0.1
1.4.2.9.0.5
Component
Firmware Version
Facepanel
1.9
1.4.2.9.0.5
General Update Requirements:
This is for the Fader Display Units built into the console. Please follow the instructions for Cobalt Motorized Fader Wings separately.
Step 1: Exit Cobalt and power off the console.
Step 2: Press and hold the top left master potentiometer and bottom left flash button on the Fader Display Unit as power is turned back on.
Step 3: Using the external Mouse, Select System Settings from the Welcome Screen.
Step 4: Press [Alt]+[F11] on the external keyboard to launch Process Explorer
Note-Icon.png Process Explorer may start minimized on the main screen. If so, choose the restore button to view Process Explorer
Step 5: In Process Explorer, navigate to the File menu and choose Run…
Step 6: Type explorer in the Open: field and click {OK} or press Enter.
Step 7: Using the Windows Explorer window, navigate to C:\etc\nodesbin
Step 8: Right click on the following file name and choose copy
14d5.0036_Display_1.0.4.9.0.16.afx.S19
Step 9: Using the Windows Explorer window, navigate to the drive labeled BOOTLOADER, right click and choose Paste to copy the firmware to the component.
Important-Icon.png If you see more than one drive labeled BOOTLOADER, abort this update attempt and restart the console. If you continue to see multiple drives labeled BOOTLOADER, contact ETC Technical Services.
Step 10: Close all open windows including Windows Explorer and Process Explorer. Click {OK} in System Settings and power off the console.
Step 11: This component is now ready for use on the next normal power up. Repeat these steps for all Fader Display Units built into the console.
