Congo Jr Windows 7 Upgrade Eligibility
See also:  Is My Console XPe or Windows 7?
This program will end on March 31, 2021, subject to parts availability.
What it is
An upgrade to Windows® 7 Embedded Standard, which includes a new hardware (motherboard, solid state drive, etc…) for some consoles in the Eos, Congo, and Cobalt family. Compatibility information is listed below. Note that if you have a Universal Fader Wing, there are some changes to consider  -- see “Things to Know” below.
How it happens
Contact your local ETC Technical Services office for details. Have the serial numbers of your console and any fader wings handy so ETC can help you verify eligibility.
For customers in the United States, consoles must be sent in on a repair order (RMA) arranged with an ETC dealer. Click here to find a dealer.
Features
In addition to a solid state drive, this will allow upgraded consoles to use a wider variety of touch screens. For more information on compatible touch screens, see this support article.
Differences Between "Upgrade" and "Rebuild"
Windows 7 Upgrades require ETC to replace the motherboard, solid state drive, etc., whereas Windows 7 Rebuilds require ETC to replace not only the motherboard, solid state drive, etc., but the face panel and other internal components must be rebuilt or replaced to support the Windows 7-compatible hardware. Windows 7 Rebuilds are offered at a higher cost than the Windows 7 Upgrade due to the extra components that must be replaced. Contact your ETC Dealer for pricing.
What is Eligible
The following consoles are eligible for an upgrade. If your console is not listed in the tables below, it is not eligible for an upgrade.
NOTE: All Eos Ti, Gio@5, Gio, Ion XE and Element 2 consoles are already running Windows 7 Embedded operating system, as are all Cobalt 20 and Cobalt 10 consoles.
Element
Only original Element consoles with part numbers starting with 4330 are eligible for upgrade. No Elements require rebuild.
Ion
Ion consoles manufactured after July 24, 2009 are eligible for the Windows 7 Upgrade.
Ion consoles manufactured before July 24, 2009 are eligible for the Windows 7 Rebuild.
Part number Eligible for Windows 7 Rebuild Eligible for Windows 7 Upgrade
4310A1012 433202099 and earlier 433202100 and later
4310A1013 433300225 and earlier 433300226 and later
4310A1014 433400310 and earlier 433400311 and later
4310A1015 433500004 and earlier 433500005 and later
4310A1016 433600024 and earlier 433600025 and later
Congo Jr
Congo Jr consoles manufactured after July 24, 2009 are eligible for the Windows 7 Upgrade.
Congo Jr consoles manufactured before July 24, 2009 are eligible for the Windows 7 Rebuild.
4320A1001 402001099 and earlier 402001100 and later
4320A1102 412000023 and earlier 412000024 and later
Congo Kid
All Congo Kid consoles are eligible for the Windows 7 Upgrade
Congo Light Server
Part number Eligible for Windows 7 Upgrade
7310A1021 Not eligible
7310A1121 434001001
7310A1022 Not eligible
Congo Light Servers with a dual-DVI splitter are not eligible for upgrade.
Ion RPU
4310A1124 433701001
4310A1024 Not eligible
4310A1025 433710003
4310A1026 433720029
Ion RPUs with a dual-DVI splitter are not eligible for upgrade.
 Net3 RVI
4250A1117 418302001
4250A1017 Not eligible
Net3 RVIs with a dual-DVI splitter are not eligible for upgrade.
Eos RPU
4250A1012 Not eligible
4250A1112 417001001 (contact ETC Technical Services)
4250A1060 419220001 (contact ETC Technical Services)
4250A1013 418000075 (contact ETC Technical Services)
4250A1025 418600004 (contact ETC Technical Services)
4250A1026 Not eligible
Eos RPUs with a dual-DVI splitter are not eligible for upgrade.
Things to know
If you have an older Universal fader wing or Congo/Cobalt Master Playback Wing (without an orange USB connector on the back), your fader wing setup may change. Specifically, you would need to follow the connection guidelines for a USB 2.0 console listed in the Fader Wing Setup guide. The fader wing cannot be docked directly, and instead would need to be run with a separate USB cable to the console or pass through a USB 1.1 hub.
Fader wings with orange USB connectors (USB 2.0 compatible) can continue to be used as-is, without a USB Hub.
Older fader wings may be upgraded to USB 2.0 to avoid the need for a USB hub.
1 x 20 Universal Fader Wings cannot be upgraded, and should not need an upgrade as they cannot be docked.
Congo/Cobalt Master Playback Wings cannot be upgraded.
 Universal Fader Wing Retrofit Kits
Part number Retrofit Kit
4310A1002 - 2x10 Universal Fader Wing
4310K1011 – 2x10 Fader Wing Retrofit Kit
4310A1003 - 2x20 Universal Fader Wing
4310K1012 – 2x20 Fader Wing Retrofit Kit
When consoles are upgraded, the old hard drive in the unit will be replaced and not returned - show files on the old hard drive will be moved to the new hard drive. Be sure to back up your data as an extra precaution before sending it in.
Windows is a Registered Trademark of Microsoft Corporation in the United States and other Countries
