Manually Update the Cobalt Light Server Facepanel
Cobalt 10/20
Component
Firmware Version
Keyboard Master
1.1.0.9.0.0
Fader Display Unit
1.0.4.9.0.16 / 1.0.5.0.16*
Independent Master
1.0.1.9.0.5 / 1.0.2.9.0.6*
Playback Master
1.0.3.9.0.8 / 1.0.4.9.0.9*
Full Speed I/O Card (with Phone Remote)
1.4.2.9.0.5
High Speed I/O Card (without Phone Remote)
1.1.0.9.0.4 / 1.1.1.9.0.5*
Cobalt Programming Wing
Component
Firmware Version
Programming Wing
1.1.0.9.0.0
Encoder Board
1.0.1.9.0.9 / 1.0.2.9.0.10*
Playback Master
Full Speed I/O Card
1.4.2.9.0.5
High Speed I/O Card
Cobalt Motorized Fader Wing
Component
Firmware Version
Fader Wing
1.0.4.9.0.21 / 1.0.5.9.0.22*
Cobalt Light Server
Component
Firmware Version
Light Server 10x2 Button
1.1.0.9.0.1
1.4.2.9.0.5
Component
Firmware Version
Facepanel
1.9
1.4.2.9.0.5
General Update Requirements:
Manually Updating the Cobalt Light Server Facepanel (Cobalt Light Server)
Step 1: Exit Cobalt and power off the console.
Step 2: Press and hold the top and bottom left buttons on the Cobalt Light Server as power is turned back on.
Step 3: Using the external Mouse, Select System Settings from the Welcome Screen.
Step 4: Press [Alt]+[F11] on the external keyboard to launch Process Explorer
Process Explorer may start minimized on the main screen. If so, choose the restore button to view Process Explorer.
Step 5: In Process Explorer, navigate to the File menu and choose Run…
Step 6: Type explorer in the Open: field and click {OK} or press Enter.
Step 7: Using the Windows Explorer window, navigate to C:\etc\nodesbin
Step 8: Right click on the following file name and choose copy
14d5.0034_Rpu_1.1.0.9.0.1.sx
Step 9: Using the Windows Explorer window, navigate to the drive labeled BOOTLOADER, right click and choose Paste to copy the firmware to the component.
If you see more than one drive labeled BOOTLOADER, abort this update attempt and restart the console. If you continue to see multiple drives labeled BOOTLOADER, contact ETC Technical Services.
Step 10: Close all open windows including Windows Explorer and Process Explorer. Click {OK} in System Settings and power off the console.
Step 11: This component is now ready for use on the next normal power up.
