Manually Update the High Speed I/O Card
Cobalt 10/20
Component
Firmware Version
Keyboard Master
1.1.0.9.0.0
Fader Display Unit
1.0.4.9.0.16 / 1.0.5.0.16*
Independent Master
1.0.1.9.0.5 / 1.0.2.9.0.6*
Playback Master
1.0.3.9.0.8 / 1.0.4.9.0.9*
Full Speed I/O Card (with Phone Remote)
1.4.2.9.0.5
High Speed I/O Card (without Phone Remote)
1.1.0.9.0.4 / 1.1.1.9.0.5*
Cobalt Programming Wing
Component
Firmware Version
Programming Wing
1.1.0.9.0.0
Encoder Board
1.0.1.9.0.9 / 1.0.2.9.0.10*
Playback Master
Full Speed I/O Card
1.4.2.9.0.5
High Speed I/O Card
Cobalt Motorized Fader Wing
Component
Firmware Version
Fader Wing
1.0.4.9.0.21 / 1.0.5.9.0.22*
Cobalt Light Server
Component
Firmware Version
Light Server 10x2 Button
1.1.0.9.0.1
1.4.2.9.0.5
Component
Firmware Version
Facepanel
1.9
1.4.2.9.0.5
General Update Requirements:
Manually Updating the High Speed I/O Card (Cobalt Programming Wing)
This process is only for the High Speed I/O card. Full Speed I/O cards should be updated following the procedure for Updating Full Speed I/O Cards.
With the exception of the Cobalt Programming Wing, the Full Speed I/O card can be identified by the presence of a Phone Remote (RJ11) port. All Cobalt Programming Wings shipped without a Phone Remote port.
Step 1: Exit Cobalt and power off the Programming Wing.
When powering off the Programming Wing, it is easier to remove power from the IEC cord to the adapter than disconnecting and reconnecting the locking barrel connector.
Step 2: Remove the bottom panel of the Programming Wing by removing the highlighted 14 screws.
Step 3: Remove the I/O card from the Programming Wing by removing the 7 highlighted screws.
Do not disconnect the cables connecting the I/O Card to the Programming Wing
Step 4: Fold the I/O card back so that the top is visible and then press and hold the Boot button as power is turned back on.
Step 5 (Console Users Only – Computer Users skip to Step 9): Using the external Mouse, Select System Settings from the Welcome Screen.
Step 6 (Console Users Only – Computer Users skip to Step 9): Press [Alt]+[F11] on the external keyboard to launch Process Explorer
Process Explorer may start minimized on the main screen. If so, choose the restore button to view Process Explorer.
Step 7 (Console Users Only – Computer Users skip to Step 9): In Process Explorer, navigate to the File menu and choose Run…
Step 8 (Console Users Only – Computer Users skip to Step 9): Type explorer in the Open: field and click {OK} or press Enter.
Step 9: Using the Windows Explorer window, navigate to C:\etc\nodesbin
Step 10: Right click on the following file name and choose copy
14d5.0113_IO_Kinetis_v1.1.0.9.0.4.S19
Step 11: Using the Windows Explorer window, navigate to the drive labeled BOOTLOADER, right click and choose Paste to copy the firmware to the component.
If you see more than one drive labeled BOOTLOADER, abort this update attempt and restart the console/computer. If you continue to see multiple drives labeled BOOTLOADER, contact ETC Technical Services.
Step 12: Close all open windows including Windows Explorer and Process Explorer. Click {OK} in System Settings (Console Users Only) and power off the console/Programming Wing.
Step 13: Restore the I/O Card back to its original position and secure using the screws removed in Step 3.
Step 14: Replace the bottom cover and secure using the 14 screws removed in Step 2.
Step 15: This component is now ready for use on the next normal power up.
