Replacing the hydraulic screen adjuster on Consoles
Problem
When the console's display adjustment button is pushed down, the display does not move up or down or it requires quite a bit of effort to move it.
Some consoles with adjustable displays utilize a hydraulic piston to hold the display's position. Over time, the piston can wear out or leak fluid and it may become necessary to replace it.
Service kits are available for purchase to complete this replacement yourself.  Please refer to the chart below to identify the correct part number for your console. Instructions to perform the replacement are included with each kit and are also linked in the table below.
Kit Name Part Number  Instructions
COBALT 10 DISPLAY PISTON SERVICE KIT 4370K1007 Cobalt 10 Display Piston Replacement Instructions
COBALT 20 DISPLAY PISTON SERVICE KIT 4370K1008 Cobalt 20 Display Piston Replacement Instructions
GIO DISPLAY PISTON SERVICE KIT 4240K1060 Gio Display Piston Replacement Instructions
GIO@5 DISPLAY PISTON SERVICE KIT 4390K1060 Gio @5 Display Piston Replacement Instructions
TI DISPLAY PISTON SERVICE KIT 4350K1011 Eos Ti Display Piston Replacement Instructions
