Congo Sr - Will Not Boot
Congo Sr. console will not boot.  Sometimes will not power on at all.
CMOS has likely has lost settings, often due to a dead coin cell battery.  When the battery dies, the CMOS settings go back to default, but the Congo Sr has special settings.
  1. Try pressing the Reset button at the back of the console while console has power
    1. If the console has a rocker power switch, the switch must be turned on.
    2. If the console has a momentary power switch, try pressing the momentary and Reset independently or both at the same time.
  2. Press F2 as the console powers on until the console enters BIOS settings menu.
  3. Correct the BIOS settings according to this document - Congo Bios Settings - 1 page.pdf
    1. Pay special attention to the Power Control Configuration.
      1. If the console has a rocker power switch, After Power Failure = Stay OFF
      2. If the console has a momentary power switch, After Power Failure = Stay ON
  4. Press F10 to save settings, and let the console reboot itself.
