Manually Update the Cobalt Keyboard Master
- Last updated
- Jun 3, 2019
- Save as PDF
Cobalt 10/20
Component |
Firmware Version |
Keyboard Master |
1.1.0.9.0.0 |
Fader Display Unit |
1.0.4.9.0.16 / 1.0.5.0.16* |
Independent Master |
1.0.1.9.0.5 / 1.0.2.9.0.6* |
Playback Master |
1.0.3.9.0.8 / 1.0.4.9.0.9* |
Full Speed I/O Card (with Phone Remote) |
1.4.2.9.0.5 |
High Speed I/O Card (without Phone Remote) |
1.1.0.9.0.4 / 1.1.1.9.0.5* |
Cobalt Programming Wing
Component |
Firmware Version |
Programming Wing |
1.1.0.9.0.0 |
Encoder Board |
1.0.1.9.0.9 / 1.0.2.9.0.10* |
Playback Master |
Full Speed I/O Card |
1.4.2.9.0.5 |
High Speed I/O Card |
Cobalt Motorized Fader Wing
Component |
Firmware Version |
Fader Wing |
1.0.4.9.0.21 / 1.0.5.9.0.22* |
Cobalt Light Server
Component |
Firmware Version |
Light Server 10x2 Button |
1.1.0.9.0.1 |
1.4.2.9.0.5 |
Component |
Firmware Version |
Facepanel |
1.9 |
1.4.2.9.0.5 |
General Update Requirements:
Manually Updating the Cobalt Keyboard Master (Cobalt 10, 20, Programming Wing)
Step 1: Exit Cobalt and power off the console or Programming Wing.
When powering off the Programming Wing, it is easier to remove power from the IEC cord to the adapter than disconnecting and reconnecting the locking barrel connector.
Step 2: Press and hold the [Update] and [Record] buttons on the Keyboard Master as power is turned back on.
Step 3 (Console Users Only – Computer Users skip to Step 7): Using the external Mouse, Select System Settings from the Welcome Screen.
Step 4 (Console Users Only – Computer Users skip to Step 7): Press [Alt]+[F11] on the external keyboard to launch Process Explorer
Process Explorer may start minimized on the main screen. If so, choose the restore button to view Process Explorer
Step 5 (Console Users Only – Computer Users skip to Step 7): In Process Explorer, navigate to the File menu and choose Run…
Step 6 (Console Users Only – Computer Users skip to Step 7): Type explorer in the Open: field and click {OK} or press Enter.
Step 7: Using the Windows Explorer window, navigate to C:\etc\nodesbin
Step 8: Right click on the following file name and choose copy
14d5.0037_Keyboard_89_1.1.0.9.0.0.sx |
Step 9: Using the Windows Explorer window, navigate to the drive labeled BOOTLOADER, right click and choose Paste to copy the firmware to the component.
If you see more than one drive labeled BOOTLOADER, abort this update attempt and restart the console/computer. If you continue to see multiple drives labeled BOOTLOADER, contact ETC Technical Services.
Step 10: Close all open windows including Windows Explorer and Process Explorer. Click {OK} in System Settings (Console Users Only) and power off the console/Programming Wing.
Step 11: This component is now ready for use on the next normal power up.
