ETCnomad Puck Base Reporting as 512 Outputs Instead of 1024
Symptoms
I updated software to v2.9.1 or v3.1.2 and my ETCnomad Puck is reporting a system count of 512 outputs rather than the 1024.
Explanation of Issue
In version 2.9.1 and v3.1.2 there was a bug in which Eos used the wrong output count for ETCnomad Pucks with SD card readers.
  1. If running the 2.9 branch of software, update to 2.9.2 or higher.
  2. If running the 3.1 branch of software, upgrade to v3.1.3 or higher.
Related Links/References
