Equipment Needed to Output DMX from ETCnomad or ETCnomad Puck
While an ETCnomad dongle or ETCnomad Puck give you access to run Eos as Primary, Client, or Backup, you will need additional equipment to actually output.
If you are using a network connection from the computer or ETCnomad Puck, you can use sACN or ArtNet gateways to output via a network
If you are using a USB connection from the computer or ETCnomad Puck, you can use a Gadget I, Gadget II, or Eos Programming Wing to go from USB to DMX.
Network and Output Devices Homepage
