What equipment do I need in addition to ETCnomad or ETCnomad Puck to output
While an ETCnomad dongle or ETCnomad Puck give you access to run ETCnomad as Primary, Client, or Backup, you will need additional equipment to actually output.
If you are using a network connection from the computer or Puck, you can use gateways to go from network to DMX.
If you are using a USB connection from the computer or Puck, you can use a Gadget II to go from USB to DMX.
