Desk Lamp Light Level Not Holding the Correct Value on Element 2
When adjusting the desk lamps light level, the intensity of the light will change to user adjusted level and then jump to ≈ half intensity.
ETC has found in some instances that the desk lamps light level is not updating properly. The input pin for the dimmer pot on the I/O cards microprocessor is not used and without reference can interpret the incidental data on the pin.
  1. Place a jumper (ETC part number J115-f) on pins 1 and 2 of the "dimmer pot" connector on the I/O PCB.
  2. Pin 1 is indicated by a ▲ on the silk screen.
                     BEFORE                                                          AFTER
