With the introduction of Eos 3.0.0 software, one of the keycaps on your console will need to be changed.
Instead of the "Scroll Lock" key, Eos 3.0.0 uses a "Stage" key.
For Element 2 consoles, the part number for the keycap replacement kit is 4331K1025. The kit includes the keycap, a key puller, and instructions. If you only need the keycap the part number is 4331A2002.
If you have the serial number of your console, you can confirm the kit you need, and order here: https://www.etcconnect.com/keycap-selector/
