Disabling Touch Screen Monitor Beeps on Net 3 RVI
I've got a touch screen hooked up to my console. Every time I touch somewhere on the screen, the console will beep.
Description
On some generations of Eos Family Consoles, touch screens may cause the console to beep when touched. The steps below will walk you through how to disable the beeping.
  1. Exit out to the shell.
    1. Double-Tap the [Displays] or [Browser] key on your console then double-click on Exit within the browser.
  2. Navigate to {Settings}>{Maintenance}>{ETC Touch Screen Settings...}.
  3. This will open an "eGalaxTouch : USB Controller" window. Click on the {Setting} tab.
  4. De-select "Beep On Touch" then hit "{Apply}"
