Troubleshooting Missing Modules on Eos Programming Wing
This support post will list what modules you should see in Detected Modules on your Programming Wing under Settings>Maintenance>Detected Modules, if plugged into a PC. If any are missing, please contact ETC Technical Support for assistance.
Description
Programming Wing should always list the following modules but the order and verbiage may vary:
Detected Modules
If you are using fader wings or additional Gadgets for output, you may see a combination of the following as well:
Detected Modules
  •      Main Playback
  •      Face Panel
  •      I/O Board
Related Links/References
