Moving Tab 1 (Channels) and Tab 2 (PSD) to Other Workspaces
Question
How do I move Tab 1 and 2 to different workspaces?
Description
While Tab 1 and Tab 2 cannot be closed, they can be moved to different workspaces. The steps below will walk you through accomplishing this.
In order to move Tab 1 and Tab 2 to different workspaces, you must have at least 2 monitors plugged into your console or 2 windows active on ETCnomad.
  1. Start with both monitors on Workspace 1.
  2. With both monitors on Workspace 1, Select Tab 1.
  3. Move Tab 1 to Monitor 1 by tapping [Tab]+[Page Right] until that tab is on Monitor 1.
  4. Select Tab 2 and repeat move it to Monitor 1 by again tapping [Tab]+[Page Right] until it is on Monitor 1.
Monitor 2, Workspace 1:
Monitor 1, Workspace 1:
  1. Switch Monitor 2 to Workspace 2 or Workspace 3.
  2. Select Tab 1 and move it to Monitor 2 by tapping [Tab]+[Page Right] until it is on Monitor 2.
  3. Repeat this process for Tab 2.
Monitor 2, Workspace 3:
  1. Switch Monitor 2 back to Workspace 1 and you will see Tab 1 and Tab 2 no longer exist in Workspace 1
Related Links/References
