Copying cues on Express consoles
You may want to use a cue’s channel levels as the foundation for a new cue, group or submaster.53 Use the following procedure to perform a copy operation. This copy may be performed either in Blind or in Stage.
To copy a cue to another cue in Stage, follow the procedure below. If copying in Blind rather than in Stage, omit step 3 from this procedure.
Keystrokes: Actions:
1. Press [Stage]. Selects the Stage display
2. Press [Cue] [1] Prompt reads:
Select cue number
To select cue type, press TYPE
3. Press [Go].
4. Press [Record] Prompt reads:
To record cue, select number and press ENTER
To cancel, press CLEAR
5. Press [2].a Corner reads: Cue 2
6. Press [Enter]. Cue copy is complete. Channel levels have been copied from cue 1 to cue 2. You can now modify the new cue
a Press [Sub] or [Group] before the number in step 5 if you want to copy a look from a cue to a submaster or a group.
53 You cannot copy an effect cue to a group.
