Inserting cues on Express consoles
You may want to insert a cue between recorded cues. For example, you may want to modify cue 1 slightly and insert it between cues 1 and 2. You can number cues with a one-digit decimal. Therefore, you can insert up to nine cues between 1 and 2 (1.1, 1.2, etc.).
Follow these steps to insert a cue between existing cues:
Keystrokes: Action:
1. Press [Blind] or [Stage]. Selects display mode
2. Press [Cue] and enter the number of the cue to modify, then press [Enter]. Selects the desired cue
3.If you are working in Stage mode, press [Go]. Brings up cue on stage and on the display
4. Add or modify channels and cue attributes. Cue is modified
5. Press [Record]. Prompt reads:
To record cue, select number and press ENTER
To cancel, press CLEAR
6. Enter cue number with a decimal to insert it between cues (e.g., [1][.][5]). If you do not enter a new cue number, you will overwrite the existing cue. Corner reads: Cue 1.5
7. Press [Enter]. New cue 1.5 is recorded between cues 1 and 2
