Printouts Available in Express
Following is a list of all 17 options on the Print Functions menu and an explanation of the printout each will produce.
Stage Display - Reports the settings of all channels on stage.
  1. Cues - Lists cues in the show by number and attributes. Also gives the levels of all channels in each cue.
  2. Groups - Lists all groups in the show by number and label. Also gives the levels of all channels in each group.
  3. Submasters - Lists all 240 submaster memories, by submaster num- ber; upfade, dwell and downfade times; rates and labels. Also gives the levels of all channels included in each submaster.
  4. Cue List - Lists cues in the show by number and attributes.
  5. Group List - Lists all groups in the show by number and label.
  6. Submaster List - Lists all 240 submaster memories, by submaster number; upfade, dwell and downfade times; rates and labels.
  7. Macros - Lists macro sequences in the show by macro number.
  8. Patch - Prints the current dimmer-to-channel patch.
  9. Profiles - Lists all 32 profiles and their fade point intensities in the show.
  10. Channel Attributes - Lists Channel Attributes, including link lists, recorded in the show.
  11. Real Time Programs - Lists Real Time Programs in the show, with complete information.
  12. Time Code Events - Lists all Time Code events in the show, with complete information.
  13. Focus Points - Lists all focus points in the show by number and label. Also gives the levels of all channels in each focus point.
  14. Focus Point List - Lists all focus points in the show by number and label.
  15. Moving Lights - This selection brings up the Print Moving Lights menu. See the explanation below of the four choices on this menu.
Moving lights
The Moving Lights option from the Print Functions menu brings up an additional menu called the Print Moving Lights menu.
The four options on this menu and the printouts they produce are explained below.
  1. Personalities - Lists all personalities in the show and identifies the attributes of each by channel order, name, data type, independent status, LTP status and Flip status.
  2. Fixture Patch - Lists all fixtures in the show according to all parameters in fixture patch. Also identifies the channel assigned to the fixture’s intensity attribute.
  3. Attribute Setup - Lists the setup in the show for all 64 attributes by number, name and category of assignment.
  4. Encoder Setup - Lists the page-by-page setup in the show for all five encoders, for the two wheels and for the two axes of the pointing device, if installed.
