A / B Faders and Buttons Not Controlling Cues on an Express
Symptoms
The A/B faders and buttons on my Express console no longer control my cues or cuelist. The C/D faders and buttons are working properly.
Explanation of Issue
Express consoles with two banks of faders for controlling channels and/or submasters (Express 24/48, 48/96, and 72/144) have multiple operating modes they can be put into.
- Two scene
- This mode makes the top bank and the bottom bank control the same channels, in a manner similar to older, two-scene-style boards.
- One scene without subs
- This mode assigns channel control to both banks of faders.
- One scene with subs
- This mode assigns channel control to the top bank of faders, and submaster control to the bottom bank.
In Two scene mode, the A/B faders and buttons no longer control cues, but instead control the crossfade between the two scenes set by the two banks of faders.
- Hit the Setup button, and type 1, Enter to select "System Settings."
- Type 15, Enter to select "Scene Mode." It will likely already be set to "Two scene."
- Type 2, Enter to select "One scene without subs," if you want all your faders to control channels.
- Alternatively, type 3, Enter to select "One scene with subs," if you want one bank of faders to control channels, and the other to control submasters.
