Focus point spreadsheet in Express
Keystrokes: | Actions: |
1. Press [Blind] [Focus Point] [Enter]. | Selects the focus point mode of the blind display |
2. Press [S3], Spreadsheet. | Shows the focus point spreadsheet |
Creating focus points
After entering the focus point spreadsheet as explained above, create a focus point as follows.
1. Press [S2], Create Focus. | Prompt reads: To create a new focus point, select focus point number and press ENTER To cancel, press CLEAR |
2. Press [5] [Enter]. | Selects focus point 5 Prompt reads: Select channel(s |
3. Press [5] [Thru] [1][0]. | Selects channels to include Prompt reads: Enter intensity |
4. Press [Full]. | Sets channels 5 through 10 to full |
5. Repeat steps 3-4. | Continue selecting channels and setting levels until done |
Editing focus points
You may edit a focus point in the focus point spreadsheet. Follow all steps in the procedure under Creating a focus point on the previous page except Press [S1], Select Focus in step 1.
Deleting in spreadsheet
After entering the focus point spreadsheet as explained on the previous page, delete a focus point as follows.
1. Press [S6], Delete Focus | Prompt reads: To delete focus point(s), select number(s) and press ENTER To cancel, press CLEAR |
2. Press [5] [And] [6] [Enter] | Selects focus points 5 and 6 Prompt reads: To confirm, press ENTER To cancel, press CLEAR |
3. Press [Enter] [Enter]. | Deletes focus points 5 and 6 |
Replacing channel level
As a convenient editing technique, you may specify a particular level to change for a channel or number of channels.
After entering the focus point spreadsheet as explained on the previous page, replace channel level as follows.
1. Press [S1], Select Focus. | Prompt reads: Select focus point(s) |
2. Press [5] [Enter]. | Selects focus point 5 Prompt reads: Select channel(s) |
3. Press [5] [Thru] [1][0] [S3], Replace Level, [5][0]. | Selects channels 5 through 10 at level 50 to change Prompt reads: Select level to replace and press ENTER |
4. Press [Enter]. | Prompt reads: Select new level and press ENTER |
5. Press [Full] [Enter]. | Changes all channels in the range 5 though 10 with level 50 to level full |
