Inserting a Link in Express
Use the edit features softkey [S5], Insert Link, to insert an empty link number ahead of the selected or specified link. All subsequent links will be renumbered.
Note: The order in which links are recorded does not affect their operation. However, your numbering may be useful to you in terms of logical organization.
To insert a link, follow these steps:
| Keystrokes: | Action: |
| 1. Press [Setup] [1][1] [Enter]. | Selects Channel Attributes display |
| 2. Press [S7], Link List. | Selects Link List display Prompt reads: Select link number |
| 3. Press [S5], Insert Link. | Prompt reads: Select link number to insert, then press ENTER. To cancel, press CLEAR. |
| 4. Press [1] [Enter]. | Selects link 1 to insert. All links higher than 1, up to the first gap in the Link List (if any), are renumbered to make room Prompt reads: Select X wheel channel number (Precede with AND to add to existing link, or EXCEPT to delete from link) |
| 5. Proceed with normal link entry.a |
a See Setting up a link.
