Inserting cues on Express consoles
You may want to insert a cue between recorded cues. For example, you may want to modify cue 1 slightly and insert it between cues 1 and 2. You can number cues with a one-digit decimal. Therefore, you can insert up to nine cues between 1 and 2 (1.1, 1.2, etc.).
Follow these steps to insert a cue between existing cues:
| Keystrokes: | Action: |
| 1. Press [Blind] or [Stage]. | Selects display mode |
| 2. Press [Cue] and enter the number of the cue to modify, then press [Enter]. | Selects the desired cue |
| 3.If you are working in Stage mode, press [Go]. | Brings up cue on stage and on the display |
| 4. Add or modify channels and cue attributes. | Cue is modified |
| 5. Press [Record]. | Prompt reads: To record cue, select number and press ENTER To cancel, press CLEAR |
| 6. Enter cue number with a decimal to insert it between cues (e.g., [1][.][5]). If you do not enter a new cue number, you will overwrite the existing cue. | Corner reads: Cue 1.5 |
| 7. Press [Enter]. | New cue 1.5 is recorded between cues 1 and 2 |
