Merging Two Links in Express
If you move a link to a space on the Link List which already contains a link, the channels in the moved link are added to the existing link.
To move a link to an occupied space on the Link List, follow these steps:
| Keystrokes: | Action: |
| 1. Press [Setup] [1][1] [Enter]. | Selects Channel Attributes display |
| 2. Press [S7], Link List. | Selects Link List display Prompt reads: Select link number |
| 3. Press [S7], Move Link. | Prompt reads: Select link number(s) to move, then press ENTER To cancel, press CLEAR. |
| 4. Press [6] [Enter]. | Prompt reads: To move selected link(s), select target link and press ENTER To cancel, press CLEAR |
5. Press [7] [Enter] |
Prompt reads: Link already exists – To confirm, press ENTER To cancel, press CLEAR |
| 6. Press [Enter]. | The channels in link 6 are added to the channels in link 7 |
Note: To split a link apart, create a new link with the channels you want to move. Since a channel can only be in one link at a time, it will be deleted from the original link and recorded in the new link.
