Playing Macros in Express
As a macro runs, the LED in the macro’s key flashes. Only one macro may run at a time.
To run macros 1 through 5, press the appropriate macro key. For example, to run macro 1, press [M1].
To play a macro recorded in [M1] - [M5], follow these steps:
| Keystrokes: | Actions: |
| 1. Press [Stage]. | Selects Stage display mode |
| 2. Press [M#]. | Macro runs; prompt shows sequence of activity as if you were entering the keystrokes |
To run any other macro, press [M*], the number of the macro, and [Enter]. For example, to run macro 10, press [M*] [1][0] [Enter].
To play a macro without its own key, follow these steps:
| 1. Press [M*] and enter the macro number. | Prompt reads: Select macro number, then press ENTER |
| 2. Press [Enter]. | Macro runs; prompt shows sequence of activity as if you were entering the keystrokes |
Canceling a macro
To cancel a running macro, press [M*].
