Record lockout in Express consoles
You may set the console to disable the Record function. This protects a finished show from inadvertent changes.
To disable the Record function in your system, follow these steps:
Keystrokes: Action:
1. Press [Setup]. Selects Setup display
2. Press [1], System Settings, [Enter]. Selects System Settings menu. Menu indicates current status of Record Lockout
3. Press [1][3], Record Lockout, [Enter]. Prompt reads:
Enable/Disable record lockout (1 = Enable, 0 = Disable)
4. Press [1] to lock out the record function. Record is locked out. If you attempt to record anything, the prompt reads:
Record is locked out (Press CLEAR to continue)
