Softkeys in Express
Stage
| [Stage] | Stage 2 | |
| S1 | Sneak | Enable/Disable Quickstep |
| S2 | Update | Sub List |
| S3 | Background Overrides | Solo |
| S4 | Only | Previous Page |
| S5 | Follow | Next Page |
| S6 | Park | Delete |
| S7 | More Softkeys>Stage 2 | More Softkeys>Stage 3 |
| S8 | Fixture | Flash |
Stage
| Stage 3 | [Stage][Fixture][Only] | |
| S1 | Part | Position |
| S2 | Load Sub | Image |
| S3 | Color | |
| S4 | Fader | Beam |
| S5 | Rate | None |
| S6 | Attribute | |
| S7 | More Softkeys>Stage | Return |
| S8 | Step | Fixture |
Blind/Cue
| [Blind] [Cue] | Cue 2 | |
| S1 | Select Cue | Part |
| S2 | Cue List>Cue List | Follow |
| S3 | Spreadsheet>Cue SS | Solo |
| S5 | Rate | Next Page |
| S6 | Delete Cue | |
| S7 | More Softkeys>Cue 2 | More Softkeys>Cue |
| S8 | Fixture |
Blind/Cue
| Cue List | Cue SS | |
| S1 | Part | Select Cue |
| S2 | Follow | Create Cue |
| S3 | Rate | Replace Level |
| S4 | Previous Page | Previous Page |
| S5 | Next Page | Next Page |
| S6 | Delete Cue | Delete Cue |
| S7 | Enable/Disable Tracking | |
| S8 | Return>Cue | Return>Cue |
Blind/Group
| [Blind] [Group] | Group List | Group SS | |
| 1 | Select Group | Select Group | |
| 2 | Group List>Group List | Create Group | |
| 3 | Previous Page | Previous Page | Previous Page |
| 4 | Previous Page | Previous Page | Previous Page |
| 5 | Next Page | Next Page | Next Page |
| 6 | Delete Group | Delete Group | Delete Group |
| 7 | Only | ||
| 8 | Fixture | Return>Group | Return>Group |
Blind/Focus
| [Blind] [Focus Point] | Focus List | Focus SS | |
| 1 | Select Focus | Select Focus | |
| 2 | Focus List>Focus List | Create Focus | |
| 3 | Spreadsheet>Focus SS | Replace Level | |
| 6 | Delete Focus | Delete Focus | Delete Focus |
| 7 | Only | ||
| 8 | Fixture | Return>Focus | Return>Focus |
Blind/Submaster
| [Blind] [Sub] | Sub 2 | |
| 1 | Select Sub | Bump Status |
| 2 | Sub List>Sub List | |
| 3 | Spreadsheet>Sub SS | Solo |
| 6 | Delete Sub | |
| 7 | More Softkeys>Sub 2 | More Softkeys>Sub 2 |
| 8 | Fixture |
Blind/Submaster
| Sub List | Sub SS | |
| 1 | Bump Status | Select Sub |
| 2 | Hold | |
| 6 | Delete Sub | Delete Sub |
| 7 | ||
| 8 | Return>Sub | Return>Sub |
Blind/Cue/Effect
| [Blind] [Cue /Effect] (CE) | CE 2 | CE 3 | |
| 1 | Step | Step | |
| 2 | Cue List>Cue List | Step Time | Follow |
| 3 | Spread Sheet>Cue SS | In/Dwell/Out | |
| 4 | Previous Page | Low/High | |
| 5 | Next Page | Insert Step | Rate |
| 6 | Delete Cue | Delete Step | |
| 7 | More Softkeys>CE 2 | More Softkeys>CE 3 | More Softkeys>CE |
| 8 | Add Channels | Attribute>Attributes |
Blind/(Cue or Sub)/Effect
| Attributes | |
| 1 | Positive/Negative |
| 2 | Alternate |
| 3 | Reverse |
| 4 | Bounce |
| 5 | Build |
| 6 | Random |
| 7 | Random Rate |
| 8 | Return>CE |
Blind/Submaster/Effect
| [Blind] [Sub/Effect] (SE) | SE 2 | SE 3 | |
| 1 | Step | Step | Bump Status |
| 2 | Sub List>Sub List | Step Time | |
| 3 | Spread Sheet>Sub SS | In/Dwell/Out | |
| 6 | Delete Sub | Delete Step | |
| 7 | More Softkeys>SE 2 | More Softkeys>SE 3 | More Softkeys>SE |
Blind/Subroutine
| [Blind] [Cue/Subr] | Subr 2 | |
| 1 | Step | Step |
| 2 | Cue List>Cue List | Select Cue |
| 3 | Spread Sheet>Cue SS | Rate |
| 4 | Previous Page | Type/Level |
| 7 | More Softkeys>Subr 2 | More Softkeys>Subr |
| 8 | Style | Up/Down/Follow |
Stage/Fader
| [Fader] | Fader 2 | Fader 3 | |
| 1 | Select Fader | Enable/Disable Quickstep | |
| 2 | Update | Load Sub | Part |
| 3 | Background Overrides | Solo | |
| 4 | Only | Previous Page | |
| 5 | Follow | Next Page | Rate |
| 6 | Park | Delete | |
| 7 | More Softkeys>Fader 2 | More Softkeys>Fader 3 | More Softkeys>Fader |
| 8 | Return | Fixture | Step |
Stage/Park
| [Park] | |
| 1 | |
| 2 | |
| 3 | A |
| 4 | B |
| 5 | Previous Page |
| 6 | Next Page |
| 7 | |
| 8 | Return |
Patch
| [Patch] | Patch 2 | |
| 1 | Dimmer Double | |
| 2 | A | |
| 3 | B | |
| 4 | Previous Page | |
| 5 | Next Page | |
| 6 | Unpatch | Profile |
| 7 | More Softkeys>Patch 2 | More Softkeys>Patch |
| 8 | Fixture Patch>Fixture Patch | Show/Hide Labels |
Setup - System Settings (1), Output Config (2) and Clear (4)
| System Settings (1) | Output Configuration | Clear Functions | |
| 1 | DMX512 Port | Reset System | |
| 2 | DMX512 Mode | ||
| 3 | Starting Dimmer | ||
| 4 | DMX512 Speed | ||
| 5 | |||
| 6 | |||
| 7 | |||
| 8 | Return>Setup | Return>Setup | Return>Setup |
Setup - Print (5) and Options (6)
| Print Functions | Options | ESP | |
| 1 | Stop Printer | Disable MIDI | 9,600 Baud |
| 2 | Pause Printer | ESP Baud Rate > ESP | 14,400 Baud |
| 3 | 19,200 Baud | ||
| 4 | 28,800 Baud | ||
| 5 | 38,400 Baud | ||
| 6 | 57,600 Baud | ||
| 7 | 115,200 Baud | ||
| 8 | Return>Setup | Return>Setup | Return>Options |
Setup - Macro Editing (8)
| Macro Editing | Macro 2 | |
| 1 | Select Macro | On Sub-Bump |
| 2 | nsert/Replace | Off Sub-Bump |
| 3 | Delete Entry | On Trigger |
| 4 | Off Trigger | |
| 5 | Copy Macro | |
| 6 | Delete Macro | Macro Enter |
| 7 | More Softkeys>Macro 2 | More Softkeys>Macro |
| 8 | Return>Setup | Macro Wait |
Setup - ETC Link Functions (9)
| ETC Link Functions | System Status (1) | Rack Status (2) | |
| 1 | Enable/Disable ETCLink | Dimmer Double / Normal Fire Mode | |
| 2 | A | Play Backup | |
| 3 | B | Record Backup | |
| 4 | System Status | ||
| 5 | Dimmer Status | Dimmer Status | |
| 6 | Unset Dimmer | Rack Status | Select Rack |
| 7 | Set Dimmer | ||
| 8 | Return>Setup | Return>ETC Link | Return>ETC Link |
| Dimmer Status (3) | Load Management (4) | |
| 1 | Print Screen | |
| 2 | ||
| 3 | ||
| 4 | System Status | Load Check |
| 5 | Select Dimmer | Record Loads |
| 6 | Rack Status | Clear Loads |
| 7 | Cancel | |
| 8 | Return>ETC Link | Return>ETC Link |
Setup - Profiles (10), Channel Attributes (11)
| Profiles | Channel Attributes | LL | |
| 1 | Profile | Independent | Link |
| 2 | Percent | Flip | X Channel |
| 3 | Clear All | 6 Bit | Y Channel |
| 4 | Clear to End | Previous Page | Position |
| 5 | Fill Between | Next Page | Insert Link |
| 6 | Copy to Profile | LTP | Delete Link |
| 7 | Reset Profile | Link List>LL | Move Link |
| 8 | Return>Setup | Return>Setup | Return>Chan Att |
Setup - Real Time Programs (12)
| Real Time Programs | RTP 2 | |
| 1 | Select Program | Insert Program |
| 2 | Time | Copy Program |
| 3 | Astro Clock | Move Program |
| 4 | Days / Date | Previous Page |
| 5 | Macro | Next Page |
| 6 | Delete Program | |
| 7 | More Softkeys>RTP 2 | More Softkeys>RTP |
| 8 | Return>Setup | Sort |
Setup - Time Code (13)
| Time Code (TC) | TC 2 | TC 3 | |
| 1 | Internal Clock | Select Event | Insert Event |
| 2 | Clock Enable/Disable | Code Time | Copy Event |
| 3 | Manual Mode | Cue | Move Event |
| 4 | Pause Mode | Rate | Previous Page |
| 5 | Step | Bump | Next Page |
| 6 | Learn Mode | Macro | Delete Event |
| 7 | More Softkeys>TC 2 | More Softkeys>TC 3 | More Softkeys>TC |
| 8 | Return>Setup | Reset Loop | Sort |
Setup - Moving Light Functions (15)
| Personality Setup | Fixture Patch | FP 2 | |
| 1 | From Disk | Select Fixture | Select Fixture |
| 2 | Start Channel | ||
| 3 | View Personality | Personality | DMX512 Port/Start |
| 4 | Previous Page | Remote Dimmer | |
| 5 | Next Page | Swap Focus | |
| 6 | Delete Personality | Delete Fixture | Flip |
| 7 | Reset Defaults | More Softkeys>FP2 | More Softkeys >FP |
| 8 | Return>Moving Light Ftns | Return>Moving Light Ftns | Autoload Encoders |
| Attribute Setup | Encoder Setup | |
| 1 | Select Attribute | Select Encoder |
| 2 | Category | Page |
| 3 | Attribute | |
| 5 | Next Page | |
| 6 | Autoload Encoders | |
| 7 | Reset Defaults | Reset Defaults |
