Reflection: How to Set Up Slave Unit
Reflection unit.
Question:
How do you slave two Reflection consoles together?
Answer:
  • Open the console.
  • Remove Jumpers on the right of the large ribbon cable. Labeled LK2 and LK3.
  • Add jumper at "C" to the left of the large ribbon cable, Remove at "D."
  • Use a Straight Serial cable, using Pins 1-3 only.
  • Cable to be no longer than 8 feet. The shorter the better.
  • Software in both units must be 2.07 at IC5
    Cable Pin out is:
    1 = Common
    2 = DATA
    3 = CLOCK
  • Must set a unique ID number for each unit.
  • Slave face panel becomes inactive.
