My ColorSource Spot Still Doesn't Power On After Replacing the Power Supply
After replacing the Power Supply in your ColorSource Fixture it still does not power on.
There may be a failure of the Control Card.
  1. Double check that all connections between the power supply and the control card are secure and there are no wires that have come loose from the headers.
  2. Contact Tech Support with your fixture serial number to discuss options.
