ColorSource Spot V Gobo Holder Compatibility
- Last updated
- Save as PDF
Many of our fixtures use the same gobo holders, but not all of them are cross compatible. The table below lays out which pattern holders are compatible with each fixture type
| Fixture | Gobo Diameter/ Projected Diameter | Gobo Size | Gobo Type | Slot | Handle Color | Part Number |
| Standard Ellipsoidals* | 100mm / 78mm 3.75in / 3.25in |
A | Steel | Gobo | Black |
7060A1013 7060A1074 - EU Version |
| Standard Ellipsoidals* | 86mm / 68mm 3.75in / 2.75in |
B | Steel | Gobo | Black |
7060A1014 7060A1075 - EU Version |
| Standard Ellipsoidals* | 100mm / 80mm 3.94in / 3.15in |
A | Glass | Iris | Black |
7060A1074-1 |
B | Glass | Gobo | Black |
7060A1019 7060A1075-1 - EU Version |
| S4 Mini | 37.5mm / 25.4mm 1.48in / 1in |
E | Steel | Gobo | Black | 7063A2010 |
E | Steel | Gobo | White | 7063A2010-1 |
E | Steel | Gobo | Silver | 7063A2010-5 |
| S4 Jr/CS Spot Jr | 66 mm /48 mm 2.75in / 2.12in |
M | Steel | Gobo | Black | 7062A1010 |
| Irideon FPZ | 37.5mm / 25.4mm 1.48in / 1in |
E | Steel & Glass (dual slots) |
Gobo | Black | 7191A2000 |
Gobo | White | 7191A2000-1 |
Gobo | Silver | 7191A2000-5 |
| HID XT | 37.5mm / 25.4mm 1.48in / 1in |
B | Steel | Install | Black | 7065A1011 |
B | Glass | Install | Black | 7065A1012 |
*For purposes of this article, a standard ellipsoidal includes any fixture with a Standard or XDLT Shutter Barrel installed. This list may include: S4, S4wrd, S4 LED S1-3, CS Spot, CS Spot V, and CS Spot VXT
