Replacing the LED Module on a Relevé Spot
Steps
  1. Unplug the following wires from the LED Driver PCB
    • J14 - Effects Module Power
    • J13 - Optics Module Power
    • J12 - Power In
    • J8 & J9 - CAN Data
  2. Make sure to also remove the grounding wire that is attached via a nut on the side of the module
  3. Loosen the 12 nuts attaching the module to the fixture
  4. Carefully remove the module from the fixture
  5. Follow the steps in reverse, installing your new LED module and tightening the 12 nuts
  6. Reconnect the wiring to the Motor Driver PCB
    • J12 - Power In
  7. Finally, make sure to reattach the grounding wire to the module
