Dimmer Settings for Use with Source 4WRD
How to configure various ETC dimmer system circuits to work with S4WRD fixtures, including Sensor, Unison DRd, Legacy Unison, and Smart systems.
For assistance changing any dimmer settings, please feel free to call Technical Support.
For DMX Mode:
Set dimmer to a switched state or use a relay when controlling Source 4wrd in DMX mode.
For Line Dimming from 120v or 240v systems:
CEM3 with a D20 or ED15
Parameter Value D20 Value ED15
Curve Mod Square Mod Square
Threshold 1% 1%
Min Scale (Percentage) 5 % 1%
Max Scale (Percentage) 100 % 100%
Regulation Off Off
Preheat Disabled Disabled
Inrush Protect OFF OFF
DC Prevent OFF OFF
Scale Load 100 100
Control Smoothing
All of these settings are available in the [Setup] menu on the CEM3 itself under [Dimmers].
The SCR Off Time may need to be increased from the default setting. Please contact ETC technical support for assistance in changing the SCR Off Time if necessary.
CEM3 with an ELV10
Parameter Value D20
Curve Mod Square
Threshold 1%
Min Scale (Percentage) 11%
Max Scale (Percentage) 100%
Regulation Off
Preheat Disabled
Inrush Protect OFF
DC Prevent OFF
Scale Load 100
Control Smoothing
CEM+ with D20 or ELV10
All settings for CEM+ can be accessed when logged in as a POWER USER via the user interface. Code is [3][3][3][3].
Parameter Value D20 Value E15
Threshold 1% 1%
Min Scale 6V 12V
Max Scale 140V 280V
Regulation Off Off
Inrush Protect OFF Off
DC Prevent OFF Off
Scale Load 100 100
In CEM+ it is very important that Max Scale be set to 140V for 120v systems or 280v for 240v systems. If this is not set then Regulation will never be truly disabled.
Unison DRd with D20
Parameter Value
Curve Linear
Mode LED Smoothing Fwd
Min Scale 13V
Threshold 0%
Dynamic Preheat 0 seconds
Transformer Mode On
Unison DRd with ELV10
Parameter Value
Curve Linear
Min Scale 15V
Threshold 0%
Transformer Mode On
Voltage Regulation Off
Unison Legacy DR and Sensor Classic with D20
Dimming with Unison Legacy DR and/or Sensor Classic racks is not ideal. Below 6% the unit will misfire (jump from full to off and back), but above should dim smoothly. Unfortunately there is no way in the older software to set a minimum threshold and avoid the poor dimming below 6%.
We do not recommend using Source 4wrd with Unison Legacy DR or Sensor Classic dimming.
We do not recommend using Source 4wrd with a Dimmer Doubler.
Smartbars and Smartpacks
Smartbars and packs do not have many settings that can be changed. The good news is that they run unregulated at all times. This means that S4wrd can function on these dimmers. They may appear steppy at some points of the fade, but they will dim.
REPORTING DIMMER SETTINGS FOR NON-ETC DIMMERS
If you are using S4wrd with another manufacturers dimmers, and have found settings that work for you, please let us know so we can share that information with other users.  To report the proper settings, please e-mail the rack and dimmer information and settings to service@etcconnect.com.
