HID Ballast Part Numbers for Source Four
For US/non-CE applications
It is not possible to replace parts within the burner / ballast assembly of Source Four HID fixtures.  If there is a problem with either the burner or the ballast, the entire assembly must be replaced.
Source Four + Source Four Jr HID Ballast Part Numbers:
The black Source Four HID 120V / 150W ballast kit is ETC part number 7060K1015 (S4 HID BALLAST REPLACEMENT KIT UL). This kit includes the ballast, the burner, and the hardware to attach the ballast to the yoke.  For a white ballast and burner, the part number is 7060K1015-1.
The black Source Four HID 120V - 277V / 70W ballast kit is 7060K1022.  For a white ballast and burner, the part number is 7060K1022-1.
The black Source Four HID 277V / 150W ballast kit is 7060K1023.  For a white ballast and burner, the part number is 7060K1023-1.
Source Four PAR and PARNel HID Ballast Part Numbers:
The black Source Four HID PAR and PARNel 120v, 150W ballast kit is ETC part number 7061K1001 (S4PAR 120V 150W HID BALLAST KIT UL).  This kit includes the ballast, the burner, and the hardware to attach the ballast to the yoke.  For a white ballast and burner, the part number is 7061K1001-1
The black Source Four HID PAR and PARNel 277v, 150w ballast kit is ETC part number 7061K1003.  For a white ballast and burner, the part number is 7061K1003-1.
The black Source Four HID PAR and PARNel 120v - 277v, 70w ballast kit is 7061K1002.  For a white ballast and burner, the part number is 7061K1002-1.
For CE Applications
The following section refers to CE versions of products
Revisions
There have been 3 different ballast types used
Metrolight
These have a ribbed outer case
The lamp holder to ballast loom can not be replaced - if repair is required, use the ballast kit that includes ballast, loom and lampholder (see spare parts below)
Tridonic
Spare Parts
 7060B2014   S4 Profile Lamp holder/ceramic and loom (NOT SUITABLE FOR METROLIGHT)
 7060K1215 a  S4 Profile 240v 150w Ballast (includes Burner, lamp holder/ceramic, and loom)
 7060A2500-0X  S4 Profile 240v 70w Ballast (includes Burner, lamp holder/ceramic, and loom)
 7061B2015  PAR/PARNEL lamp holder and loom (NOT SUITABLE FOR METROLIGHT)
 7061K1201 a
 PAR/PARNEL 240v 150w Ballast (includes Burner, lamp holder/ceramic, and loom)
 7061A2245-0X  PAR/PARNEL 240v 70w Ballast (includes Burner, lamp holder/ceramic, and loom)
a: add -1 for white
Replacement Lamps
 RT157  CDM150/T6/830 - 150w 14,000 Lumens, 3000k
 RT158  CDM150/T6/942 - 150w 12,700 Lumens, 4000k
 RT212  CDM70/T6/830 - 70w 6,600 Lumens, 3000k
 RT214  CDM70/T6/942 - 70w 6,600 Lumens, 4000k
