Display Hardware and Software Update in S4LEDS2
After replacing the display on my fixture, or downgrading the fixture to an earlier version, the first line of text seems cut off or incorrect.
Explanation of Issue
In February of 2022, a change went into effect on the display assemblies for D22/40/60 and S4LED Series 1 & 2 fixtures causing them to require new drivers.
If you run older software with displays shipped after this date, the text will wrap around to the next line.
While the display is still readable and the fixture will function normally, it will look wrong.
S4LED/Desire Software v1.8.2 was released to correct the issue. Updating your fixture to 1.8.2 should return the display rendering to normal
