S4 Series 3 case screws do not fit
S4 Series 3 case screws do not fit.  They are either too big and do not fit in the hole or are too small and drop in.
The casting on the S4 Series 3 fixture was changed.  The 4 case screws size was also changed.
  • Old screws are a bigger diameter and only fit older cases.
  • New screws are a smaller diameter and different thread count so they only work with the new case.  They will just fall into the bigger hole of the old case.  They may be a bit longer also.
  1. Use the other screw type.
