DOS Navigation Tricks
CHDIR or (CD)
Displays the name of the current 'directory or changes the current directory.".." move one directory up. "\" changes to the root.
COPY
Copies one or more files to the location you specify.
DEL
Deletes the files you specify. /P Prompt
DELTREE (Be careful with this command!!!!!)
Deletes a directory and all the files and sub directories that are in it.
DIR
Displays a list of the files and subdirectories that are in the directory you
specify.
/W = Wide   /P = Pause
/A D = Directories only /A -D = Without directories
Sorting:
 /O N  by name ,Alphabetically
 /O D  By date earliest first
 /O S  By size Smallest first
MKDIR or (MD)
Creates a directory.
You can use the MKDIR or MD command to create a multilevel directory
RMDIR or (RD)
Deletes (removes) a directory.
Before you can delete a directory, you must delete its files and subdirectories. The directory must be empty except for the "." and ".." symbols.
XCOPY
Copies directories, their subdirectories, and files (except hidden and system files). With this command, you can copy all the files in a directory, including the files in the subdirectories of that directory.
