Can You Convert CEM+ Configuration to CEM3 Configuration Using Concert
Yes, you can convert a CEM+ configuration file to CEM3 using Net3 Concert.
Exporting CEM+ Configuration
  1. Open Net3 Concert with your CEM+ racks in.
  2. Right Click on the rack and select 'Export Group Sensor File'
  3. Save the file, this is the file you will need to import into the CEM3 configuration in the steps below.
Importing CEM+ Configuration
  2. Add a CEM3 to the layout that matches the size of the CEM+ rack you're importing and you have set the correct rack number.
  3. Double click on the CEM3 icon to open the CEM3 rack configuration window
  4. Click on the 'Import CEM+' icon in the top left corner of the screen
  5. Follow the steps to choose and import the desired configuration
  6. Push the configuration to the CEM3 as needed
