Synced DMX Output Rate on Net3 Gateways
Question
What does the 'synced' option mean for the DMX output port on a Net3 Gateway?
Answer
This output rate is used if you have an input port on the same gateway and want the output port to match the input port's speed. If the gateway does not have any input ports, use the max-slow options for all output ports.
