Why Can't I Use Both POE and DC Power Supply to Power my Net3 or Response Mk1 Gateway?
It was mentioned in the manual not to use both POE and DC Power. Why?
Explanation of Issue
In previous versions of the manual, this was called out due to a perceived issue with the two working together. Further testing has revealed that this is not an issue and the manual has been revised to remove this limitation.
