Installing NCE V4.0.0 on Windows 98
Before installing NCE Version 4.0.0 on a computer running Windows 98 OSR2, you needed to run a program called vcredist.exe to install the appropriate Microsoft Visual C Redistributable Libraries. This software is found on the software CD under Related Documents. 4103D1005-4.0.0
This NCE Software installation installed the application and the ETCNet2 node code in the directory C:\ETC\nodesbin, overwriting existing files in that location. It also added 3 additional files:
ppimage.bin
for upgrading Two Port ETCNet2 DMX Nodes from 1.1.0 to 4.0.0 -
emphfp.bin
to add the IP address of Emphasis Facepanels into the bootp.tab file -
obs2fp.bin
- to add the IP address of Obsession 2 Facepanels into the bootp.tab file.
