Response 0-10v Gateway Data Loss Behavior
The Response 0-10v Gateway can Hold Last Look (HLL) when there is a loss of either sACN or DMX data.
This can be changed in the menu of the unit.
If Emergency is Active, HLL will not apply in this situation.
Simply go to Setup > Addressing > HLL On/Off
If HLL is set to On, the 0-10v Gateway will retain the data that was playing before it lost its streaming source.
If HLL is set to Off, the outputs will go to zero.
More information can be found in the manual below on Page 7.
Related Links/References
