EtcDaliEdit - Deleting Ballasts
A DALI Ballast is no longer in use, was part of a Short Address clash, or just plain needs to be deleted from the Response DALI Gateway without performing a Restore Defaults command.
Explanation of Issue
This will require the EtcDaliEdit software and a Gadget2 wired directly to the Response DALI Gateway
  1. Launch EtcDaliEdit and connect to the Response DALI Gateway.  (Instructions here)
  2. The ballast should appear in the table in red representing an Offline ballast.
  3. Adjacent to that red Offline label is a red X.
  4. Click the red X to delete that ballast from the Gateway.
  5. This action is immediate and does not require a configuration upload.
