Net 3 Show Control Gateway Self Test
The Net 3 Show Control Gateway has built-in self-tests for Backlight, LCD, MIDI (loop test, no MIDI source needed) and SMPTE (need a SMPTE source)
Steps to Solution
  1. Press and hold the reset button until it indicates self test (3 seconds)
  2. Navigate through the test using the soft button
  3. The unit will reset itself after the test is completed
