ColorSource Relay Weak Signal
Weak signal strength on ColorSource Relay can be a sign that the internal antenna is broken, damaged, or not working.
- Open the unit by removing the three screw on the bottom
- Replace the internal antena (M408)
- Close the unit back up.
